BRABUS Special Equipment
BRABUS engine 850 6.0 biturbo
displacement: 5,912 cc
Power: 625 kW (850 hp) at 5400 rev / min. - series: 430 kW(585 hp)
Torque: 1,450 Nm * at 2500-4500 r / min. (* Electronically limited)
Displacement increase to six liters, consisting of: finely balanced from the solid, and special crankshaft with stroke 96.00 mm
8 from the solid Spezialpleuel
8 bore forged pistons for 99,00 mm
and custom compression height Reinforced multi-layer steel (MLS) head gaskets for bore 99,00 mm
2 x BRABUS custom turbochargers with a larger compressor unit
BRABUS intake module 850 consists of:
Air filter housing with enlarged intake Diameter including air control, or in the hood
Carbon fiber clean air ducts with enlarged cross-section
Down Pipe ? 75 mm low back pressure metal catalysts
BRABUS valve-controlled sports exhaust system
BRABUS "Gold Heat Reflection" for intake - and boost tubes
Special appliqued BRABUS data as for engine control unit
Additional costs will be caused by EU-homologation and EU-registration
BRABUS front spoiler lip -visible carbon glossy-
BRABUS front skirt add-on parts -visible carbon glossy-
BRABUS rear bumper with integrated rear diffusor -visible carbon glossy-
BRABUS rear bumper add-on parts -visible carbon glossy-
BRABUS rear spoiler -visible carbon glossy-
BRABUS double-B insert for front grille
BRABUS logo for radiator grille-illuminated-
BRABUS mirror shells -visible carbon glossy-
BRABUS special painting of all chrome parts, front spoiler lip, radiator grille,
clasp on boot lid, wheel arches, and running boards in black glossy
BRABUS brake design
BRABUS Monoblock Y light alloy wheels -forged-
10J x 23 H2 offset 50 Y-spoke-design anthracite-glossy full polished -Platinum Edition-
12J x 23 H2 offset 35 Y-spoke-design anthracite-glossy full polished -Platinum Edition-
Tires front 295/35 ZR 23 Conti Sport Contact 6 108Y XL,
Tires rear 335/30 ZR 23 Conti Sport Contact 6 111Y XL,
RDK kit Schrader
