i3好像没啥好刷的,老外也就刷个放视频之类的
BDCBody Module:
Change BehaviorXSS of 3rdButton on Keyfob (short, med, long press of button)
30D0 àRC_DEFAULT_IDG_3RD_BUTTON_SHORT set to: option below
30D0 àRC_DEFAULT_IDG_3RD_BUTTON_MID set to: option below
30D0 àRC_DEFAULT_IDG_3RD_BUTTON_LONG set to: option below
30D0 à RC_DEFAULT_IDG_4TH_BUTTON_SHORT setto: option below
30D0 àRC_DEFAULT_IDG_4TH_BUTTON_MID set to: option below
30D0 àRC_DEFAULT_IDG_4TH_BUTTON_LONG set to: option below
Wert_00=No Action
Wert_02xsso_pen Trunk (rear Boot)
Wert_03=Panic Alarm
Wert_04=Follow-Me-Home (find car in dark parkinglot – lights on)
Wert_05xsso_pen Frunk (front boot)
Wert_07=Auxillary Cooling
Auto Start/Stop OFF by default
3023àTCM_MSA_DEFAULT_OFF set to: aktiv – werte=01
Auto Start/Stop – Remember LAST Setting
3023àTCM_MSA_MEMORY set to: aktiv – werte=01
Unlock all doors with engine off(Single-Pull Handles):
3040àVAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK set to: aktiv
Electronics off when door opened
3020àTCM_LOGIC_R_OFF_DOOR set to: aktiv
Start Car by pushing button (hold brake notneeded)
3000àTC_STARTLOCK_BRAKE set to: nicht_aktiv
3000àTC_STARTLOCK_DRIVINGREADINESS set to: nicht_aktiv
Increase DRL Brightnessto be brighter (increases voltage to the LED Bulbs)
3062à MAPPING_STANDL_V_L_PWM_LEVEL_1 setto: 13.7v
3062à MAPPING_STANDL_V_R_PWM_LEVEL_1 setto: 13.7v
3062à MAPPING_PARKL_1_V_L_PWM_1_LEFT setto: 13.7v
3062à MAPPING_PARKL_1_V_L_PWM_2_RIGHT setto: 13.7v
Close windows, sunroof & mirror fromkey fob:
3056à KOMFORTSCHLIESSUNG_FB (Comfort Access ONLY) Set to: aktiv 00
3110à ASP_BEIKLAPPEN Setto: aktiv
3110 à ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN Werte=01
3110à ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN Werte=01
Set Mirror Fold Delay Time
3056àKOMFORT_SCHLIESSEN Werte=00
Change Mirror Un-Fold Automatically at XXSpeed (Binary value in Werte):
3110à ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN Werte=14 (12Mph)
Turn off front window roll-up doorinterrupt (Auto-Up when door is not closed):
3050à FH_TUERAUF_STOP_MAUT setto: nicht_aktiv
Change Triple-BlinkXSS Count to another Value:
3068à BLINKZYKLEN_ANZAHL_TIPP
Werte=# blinks-1 (ie. 4 blinks=werte=3)
Turn on Brake Force Flashing with HardBraking:
3068à ESS_AKTIVIERBARER_AUSGANG set to: bremsclichtblinkend
Tilt Passenger Mirror farther down when inreverse
3110àASP_BORDSTEINAUTOMATIK_DELTA Werte=4B
Ambiance Lighting controlled independentfrom Dimmer Switch
3070àAMBIENTE_NACHFUEHRUNG setto: nicht_aktiv
Enable Illumination of Exterior Door HandleLEDs when in Reverse
3070àOVT_BEI_REUCKFAHRLICHT setto: aktiv
Turn on Fog Lights with Welcome Lights:
3063à MAPPING_NEBELSCHW_L_PART_OF Werte=10
3063à MAPPING_NEBELSCHW_R_PART_OF Werte=10
Activate Rear Fog Lights (Euro-Switch orMod Needed to switch in order to work):
3068àNSL_Verbaut Set to: Verbaut
3064àMapping_Nebelschlussl_L_output Setto: nsl_l
3064àMapping_Nebelschlussl_L_Function Set to: nebelschlusslicht
3064àMapping_Nebelschlussl_R_output Set to: nsl_r
3064àMapping_Nebelschlussl_R_Function Set to: nebelschlusslicht
Turn On Tail Lights with DRLs:
3062àMAPPING_TAGFAHRL_1_V_L_OUTPUT set to: tfl_l
3062à MAPPING_TAGFAHRL_1_V_L_OUTPUT set to: tfl_l
Auto Headlight Turn-On/OffSensitivity:
3130àRLS_DEF_FLC_SCHWELLWERT_SATZ set to: option below
3130àRLS_FLC_SCHWELLWERT_SATZ setto: option below
Options:
normal=normal
empfindlich=sensitive
sehr_empfindlich=very sensitive
unempfindlich=insensitive
HU_NBTor HU_ENTRYNAV:
Enable AM Radio
3002àRADIO_BAND_KW setto: aktiv
Enable Hold-Mode for Range Extender 这是保持住增程器长期启动的代码
3000 à EV_MENU_AVAILABLE setto: rex
Once enabled, under Settings in iDriveà Auto eDriveto enable REx manually (once battery is below 75%)
Set cell phone ringer as primary
3001àINBAND_RINGING setto: aktiv
Disable Auto-Locking of Doors once begindriving
3000àDOOR_LOCK_AFTER_DRIVING_AWAY set to: nicht_aktiv
Change Navi Voice to British English
3000àLANGUAGE_ENGLISH_UK set to: master
3000àLANGUAGE_ENGLISH_US set to: nicht_aktiv
Video In-Motion (No Longer needto be stopped with parking brake set to view videos)
3000 à SPEEDLOCK_X_KMH_MAX werte=FF
3000 à SPEEDLOCK_X_KMH_MIN werte=FF
3000 à VIDEO_HANDBRAKE setto: nicht_aktiv
3000 à VIDEO_FRONT_LOCKED setto: nicht_aktiv
3000 à VIDEO_SPEEDLOCK_CONDITION setto: none
Navi Trip-Import
3000àNAVI_TRIP_IMPORT setto: aktiv
Navi Fuel-Stop Proposal Along Route
3000àNAVI_FUELSTOP_PROPOSAL set to: aktiv
Enable Video Files from USB
3000àENT_CODEC_OGG setto: aktiv
3000àENT_CODEC_XVID setto: aktiv
3000àENT_CODEC_VCD set to: aktiv
3003àAPI_USB_VIDEO set to: both
Add GPS Current Location to Navi Menu Items
3000àNAVI_POSITION_MENU setto: aktiv
Enable the function of saving video filesto NBT Hard Drive for play later
3000à ENT_MC_VIDEO_SUPPORT setto: aktiv
Disable Office Function Speed Lock-Out
3000à OFFICE_MESSAGES_SPEEDLOCK_CONDITION set to: nicht_aktiv
Enable Full Text Lines inOffice While Driving
3003 àPIM_DRIVING_TEXT_LENGTH set to: whole text
Disable Audible Chirp/Beep When Locking Car
3000à ACOUSTICAL_LOCK_CONFIRM setto: nicht_aktiv
Enable Speeach Input for E-Mail or SMS
3003à SPEECH_2_TEXT setto: aktiv
Enable Time-Stamp Display for Call Log
3003à TIMESTAMP_DISPLAY setto: aktiv
Add Temperature & PSI to tire monitor screen
3001àRDC_SAFETY set to: aktiv
Disable Legal Disclaimers 法律声明
3001àLEGAL_DISCLAIMER_TIME setto: kein_ld
3001àMACRO_CAM_LEGALDISCLAIMER setto: kein_ld
3001àMACRO_NIVICAM_LDISCLAIMER setto: kein_ld
Change i-Drive Animationto ///M Logo
3001àSTARTUP_EMBLEM set to: variant_01
Change iDrive Animation to Standard BMWConnected Drive:
3001àSTARTUP_EMBLEM setto: variant_00
Enable Developer Menu
3000 à ENTWICKLER_MENUE setto: aktiv 01
IHKAModule:
HVAC System Remembers Last Setting
3000àOFF_MEMORY set to aktiv
HVAC System Remember Air ReCirculating(ALWAYS AUTO by default on startup)
3000àMEMORY_UMLUFT set to: aktiv
KOMBI or BKOMBI Module:
Show Digital Speed in MPH in Instrument Cluster(active by BC button cycle)
3000àBC_DIGITAL_V set to: aktiv
Enable GPS-Sync for Clockto Instrument Cluster
3000àGPS_UHR set to: aktiv
Alter Range Extender activation battery capacity level: 这是设定电量去到什么程度启动增程器
3000àSOC_HOLD_POSITION werte=hex value xx
Units are 0.5% -- default=0C which is 6% ie. 18=12%
由于我启动了保持增程功能,我就没重新调整了这个,同时因为这个算法有点奇怪,按道理是十六进制,但是默认值0C是6%,我是怕调整的参数不对,所以直接没调。不够电的时候,我直接保持增程器启动就是了。
Increase computer-limited fuel tankcapacity of REX to full 2.4 US Gallons physical capacity
3005àTNK_VOLL_ANZEIGE setto: 8_liter
3005àTNK_LITER_RECHTS set to: mcv_rex_liter_kl_rechts
3005àTNK_OHM_RECHTS set to: mcv_rex_ohm_kl_rechts
PMA_PDC Module:
Enable Rear-View Camera at all Speeds
300Bàd_schwelle_2kmh werte=FF
300Bàv_schwelle_2kmh werte=FF
另外这串代码也是在这论坛里面翻另外一名 车友找到的,也谢谢这位车友。
不是我个人能力弄出来,大家谢,就谢这位车友。
