简答的说下
如果root后使用aa mirror unlock依然无效的解决方案 一劳永逸
配置后联网不会再次丢失
需要一定的计算机基础
1 android auto改成发布模式,不再需要勾选允许未知应用.
2 root
3 复制 /data/data/com.google.android.gms/databases/phenotype.db,发送到pc端.
4 下载Navicat Premium或者第三方sqllite数据库编辑器
5 执行以下sql,添加白名单
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car#car", 234, 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car#car", 230, 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car", 234, 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car", 230, 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car#car_setup", 234, 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car#car_setup", 230, 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car#car", (SELECT version FROM Packages WHERE packageName="com.google.android.gms.car#car"), 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car", (SELECT version FROM Packages WHERE packageName="com.google.android.gms.car#car"), 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
INSERT OR REPLACE INTO Flags (packageName, version, flagType, partitionId, user, name, stringVal, committed) VALUES ("com.google.android.gms.car#car_setup", (SELECT version FROM Packages WHERE packageName="com.google.android.gms.car#car"), 0, 0, "", "app_white_list", "com.github.slashmax.aamirror",1);
6 为防止谷歌自动删除白名单,添加数据库删除触发器
CREATE TRIGGER after_delete AFTER DELETE
ON Flags
BEGIN
END;
同样,直接复制代码到数据库查询窗口运行
7 关闭窗口,复制数据库到手机并替换,权限777全给就行了
8 重启手机
如果你想添加其他app,查看包名后用逗号分隔添加即可
如 com.github.slashmax.aamirror,com.test.apk
包名查看miui为例
打开app 后台列表,长按app进入应用信息,右上角感叹号查看包名
比如我添加了如下
效果
