第一次用记录仪,淘了个原厂,淘宝有3种类型,我选的“小巧型”的。。。不带屏,用wifi手机回放视频,说明书ACC接副驾保险86,B+接79。。。安装之前百度很多帖子说是ACC接85?搞不懂。。。
画质还不错,就是不知道CPU什么方案的,视频格式为MP4,照片为jpeg。。。
视频保存到电脑上用PotPlayer播放,信息如下:
General
Complete name : E:\记录仪\DRF_20180121_170256A.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1 (avc1/isom)
File size : 270 MiB
Duration : 3 min 0 s
Overall bit rate mode : Variable
Overall bit rate : 12.6 Mb/s
Encoded date : UTC 2018-01-21 17:02:46
Tagged date : UTC 2018-01-21 17:02:46
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 12.2 Mb/s
Maximum bit rate : 12.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.196
Stream size : 261 MiB (97%)
Title : Ambarella AVC
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 3 min 0 s
Bit rate mode : Constant
Bit rate : 128 kb/s
Nominal bit rate : 44.1 kb/s
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Stream size : 2.75 MiB (1%)
Source stream size : 2.75 MiB (1%)
Title : Ambarella AAC
Language : English
Text
Format : Timed Text
Codec ID : text
Duration : 2 min 59 s
Source duration : 2 min 59 s
Source stream size : 1.05 KiB (0%)
Title : Ambarella EXT
Language : English
Forced : No
