斯巴鲁机滤数据大全--来自美国斯巴鲁论坛
Oil filters for new Subaru engines (FB).
Original (Tokyo Roki) filters (23 psid, thickness can 0.44mm):
-15208AA160 (slim): 2.76x 3.41, 1092 cm2
-15208AA130 (big): 3.19x2.91, 1240cm2 (that is why only 15208AA130 for Subaru BRZ 2013/2014)
I have found some non-original synthetic (with advanced filtration efficiency) filters (I looked only models with height more than 3”):
1)AMSOIL (11-17 psid, 9-11gpm, 98.7% at 20u, 99% at 25u, thikness can 0.55mm):
EA15K13 (former EA013): 2.65x 3.40i (Diameter x Height)
Ea15K20 (former EAO20) : 3.12 x3.08
2)Royal Purple (11-17 psid, 9-11gpm, 99% at 25u, thickness can 0.46mm):
10-2867 : 2.67x3.35
10-2808 : 3.14x3.08
3)Wix/Napa (8-11 psid, 9-11gpm, 50% at 20u) , thickness can 0.35mm
51356xp/41356 Platinum 2.68x3.40
51334XP/41334 Platinum 3.25x3.19
And models of non-synthetic filters:
51064 2.98 x 3.23 16 psi
51568 3.23x4.072 16 psi
51344 3.24x4.07
57712 : 2.68x2.58, 23 psid, only for EJ engines (thread Location of bypass valve)
57830 : 3.29x3,00, 28 psid, for FB engines,
57055 : 2.57x3.40 , 27psid, for FB engines.
4)Purolator Pure One (99.9% at 40u) and Purolator Synthetic (99% at 25u), 9-11 gpm,thickness can 0.35mm:
PL14615 : 2.69 x 2.93, 16-28 psid
PL14459 and PSL14459 : 3.15x2.95, 12-15 psid
PL14620 (former PL14610) and PSL14610 (PSL14610) 2.69x3.52, 14-18 psid
Pl24458 : 3.15 x 3.94, 12-15 PSID
PL14460 : 3.15x2.95 , 20-25 PSID, without ADBV
5)Bosch Distance Plus (99.9% at 40u) and Bosch Long life (both made by Purolator), 9-11 gpm, thickness can 0.35mm:
D3312: 3.36x3.00 , 12-15psid
D3323: 2.69x3.52, 12-15psid
6)Mobil-1 (11-17 PSID, 99% at 25u), 9-11 gpm, thickness can 0.46mm
M1-104 : 3.14 x3.08
M1-110: 2.67x3.35
7)K&N (11-17 psid, 99% at 25u), 9-11 gpm, thickness can 0.46,,
HP1004: 3.16x3.4
HP1010: 2.69x3.75
8)AFE 44LF018 N (11-17 psid, 99% at 25u), thickness can 0.46,,
