应车友询问,现特地把AMS改装厂出的五种改装方案原文翻译过来。如有出入敬请指正,大家如果有不清楚的地方,我也很乐意进一步解释。
TCX 2.4 套件
原文如下
At the heart of the AMS TCX Package is the AMS 2.2L Big Bore Short Block and the new AMS 900XP EVO X Turbo Kit. Over the last few years, the added displacement of the 2.2 liter engine had proven to substantially lower spool time of our original 900X turbocharger; so quick, we"ve used this setup as our winning combination for road racing (even prior to the development of the TDX package). By replacing the 900X with our new 900XP turbocharger, the new TCX now offers even more horsepower to fire off 10 second passes at the drag strip and more low-end torque to corner exit with the best of them. In terms of application, the AMS TCX Package is simply a great all-around performance package for any EVO X enthusiast who plans to focus mostly on Drag Racing.
译文
AMS 的 TCX 套件的核心为 2.2L 短轴活塞以及 AMS 900XP EVO X 涡轮套装。 在过去的几年中,2.2L 引擎已被证明可以和我们的 900X 活塞套装稳定匹配,所以我们很快就以他们两者为组合开发出了我们的街道冠军竞速套装 TDX。 在用新的900 XP 涡轮套装替换原有的 900X 涡轮套装后。 现在 TCX 套装可以提供更多的马力以及在直线赛道中,1.6公里10秒左右的成绩;同时在低转速区间提供更多扭距。简单来说 AMS TCX套装可以为直线赛爱好者提供全面的性能提升。
Kit Includes
Engine发动机部分组件包括
Turbo/Intercooler/Exhaust涡轮/冷却/排气系统包括
Fuel System供油系统包括
Drivetrain传动系统包括
全套价格:26000美金 不包工时。这个就是上900HP的第一种,主要跑直线的,下面是竞速类的
专业术语请各位果断百度一下,太麻烦就不一一翻译了或者直接回帖问我。
TDX 2.4套装
原文
The AMS TDX Package for the Mitsubishi Evolution X is the ultimate package making you almost unbeatable on the street or road course. This exclusive package implements all of the latest AMS parts and technology available and is capable of tripling the power output of your stock Mitsubishi Lancer Evolution X - turning it into a 850+ HP street-driven super car and placing the AMS TDX Package in a league of its own! This is the ultimate turn-key solution for those seeking unmatched power and performance for the street and road course.
Exclusive Benefits
译文
AMS TDX套装是为EVO X专门开发能使你同时在街道以及赛道战无不胜的牛逼套装。(我有点吐。。。)这套牛逼东西包括所有AMS的最新产皮以及科技,使得原厂EVO X经改造后可以爆发出 850 匹以上的马力,可以合法的将你的EVO进化为街道上的超级跑车。AMS TDX套装本身就已经成为了一个传奇。这套牛逼东西就是为寻求街道以及赛道无双表现的金钥匙。。。。(翻译的有点恶心,吐了)
主要牛逼的地方
同时提供街道/赛道的牛逼表现
在赛道已被AMS的改装时间赛EVO X证实有取得冠军的实力
可以在街上开
93号油就能跑出来700匹马力以及500的扭矩(已更正,谢谢提醒)
加赛车用油就直接850匹以上 500扭矩以上的逆天表现了
Kit Includes组件包括
Engine发动机
Fuel System 油路
Drivetrain传动
价格27000美金不包工时
看不懂的地方和前面规矩一样。
如果有想要视频的直接M我,国外视频没法转到国内帖子上,大家懂得。
下面附上几种上面提到过的牛逼涡轮套件
第一个最普通 仅仅750匹。。。
900匹。。。
950匹~。~ 从外观看我反正没发现什么大区别~
原厂调教好的2.2L引擎,已经全面强化
锻造活塞盖子
2.4L的原厂引擎现在还没有图放出来,这个是扩缸后的2.4L气缸图,等能找到做好的机器我再发上来。
输出曲线截图,请注意,那个728是轮上马力。。。够恐怖了吧
这篇文章中我犯了个普遍错误就是扭矩的单位没换算,感谢难忘旧爱和freedom_riden 的提醒,经过换算后的数值很恐怖,马力机上面的517ft/lbs =700.95N/m.瞬间感到一阵晕眩~娘子快和牛魔王出来看上帝~
