史上最全A3 8V 隐藏功能列表英文版 不断更新中!
1 87 发布于 2015-01-08 16:39:22 只看楼主 热门标准
http://www.stemei.de/pages/coding/audi-a3-8v.php
这个网站原是德文(毛文)的 我使用google trans把里面的列表翻译成英文了供大家参考 大家关心的关闭起停转向雾灯辅助都可以搞出来 大家可以一起研究 也希望大家搞好了记得把教程share一下 造福更多人!
里面目测没有我最关心的蓝牙问题 我会继续寻找 有新的进展我会po上来和大家分享!
PS:列表里面有关闭起停这一项但是打开显示编码还在开发状态(感谢热心朋友指正) 相信不久的将来就会有结果了  大家也请耐心等待一下~
MMI PLUS TV Free
TV / DVD image quality control while driving with a navigation system MMI PLUS
MMI Engineering Menu
Call Menu Engineering from the navigation system MMI PLUS
MMI reset
Demonstration of the MMI reset / restart on monkey grip
Activate MMI-Fi
Activation of the Wi-Fi function in the MMI
Cornering fog lamps
Activation of the fog lights (NSW) and Cornering
Cornering fog lamps speed bumps
Adjust the speed thresholds for activating the Abbiegelichtes fog lights
ACC distance setting in the MMI
Adjustment of the distance settings of the ACC (adaptive cruise control) via MMI
Ambient lighting
Activation / activation of ambient lighting
Start-off
Adaptation of dynamic start-off
Unlock trailer hitch
Activation of the trailer hitch
Eject Lock CD / DVD drive
Enable / disable the Eject Lock CD / DVD drive
Auto Hold function state
Adaptation of the functional state of the Auto Hold setting
Passenger drawdown
Passenger drawdown when reversing
Berganfahrassistent
Adaptation of the Hill Start Assistant
Dimmed indicator, US daytime running lights
Enable US daytime running lights for the front indicators
Parking aid cut-off threshold optical display
Adaptation shutdown threshold for the visual display of the parking aid
Park distance control distance curb
Adaptation of the threshold for display of the distance to the curb
Parking assistance Activation sound
Deactivation Activation sound of the parking aid
Parking aid requirement Audio reduction
Adjustment of the request for the audio lowering
Enable Visual display parking aid
Activated via the MMI - visual representation of the parking aid (Audi Parking System APS)
seat belt reminders
Disable seatbelt warning indicator in the instrument cluster
Disable rear wiper wipe tears
Deactivation of tears wiping function of the rear wiper
High-Beam Assistant reset
Prevent reset / reset the high-beam assistant
Unlock FIS
Driver information system (DIS) subsequently activate
Adjust air blower mode
Adjustment of the fan mode, the air conditioner
Air blower speed
Displays the fan speed in AUTO mode, the air conditioner
Komfortblinker cycle
Adaptation of the turn signal cycle
Comfort automatic key lock lock,
Automatic lock, seal off, lock the vehicle with a convenience key
Headlights speed threshold
Adjust the speed threshold of the static cornering light (cornering)
laptimer
Activation of the lap timer / lap counter in FIS
microphone sensitivity
Adjustment of the microphone sensitivity
Oil temperature gauge
Display the oil temperature gauge in the FIS laptimer
Oil temperature gauge in consumption display
Display the oil temperature gauge in the FIS consumption display
Activate tire pressure monitoring system
Activation of the tire pressure monitoring system (TPMS)
shift recommendation
Activation of the switching recommendation in FIS
Start / Stop function disable
Complete deactivation of the start / stop function
Heated seats
Adjustment of the seat heater withdrawal thresholds
Save seat heating stage
Storage of the last set stage seat heating
Enable Mirror heating
Activation of the exterior mirrors heated mirrors retrofitted with glasses
Activate voice control system
Activation of the voice control function (SDS) in a convertible
Heater reheating time
Adaptation of the reheating time the heater
Reduce SWRA activation
Adjustment of the interval of the headlight washers (SWRA)
Daytime running lights with tail light
Activation of the parking light of the rear lights to LED Daytime Running Lights
Daytime running lights dim down not
LED daytime running lights do not flash when dimming
Daytime running lights turn off in the MMI
Ability to disable the daytime running light in the MMI
Daytime running lights only in switch position auto
Activating the function daylight only in switch position of car
Daytime running lights inactive at hand brake
Disable the daytime running lights with the handbrake applied
Customize consumption display
Customize consumption display (FIS)
Ignition active message
Deactivation of the message / tone with ignition on
pointer test
Enable Pointer Test / pointer deflection / Production / Staging
Show cylinder deactivation
Enable display of cylinder deactivation
最后编辑于2015-01-09 00:13:08
共5页
1 234 5
