北漂憨人 2018/01/30 23:18:09 发表在 95楼
你懂个球。你懂就不可能说出那样的话。自然吸气的车那么看重剪切度。太搞笑了。小排量自然吸气发动机工作温度才多少。那么看重剪切度干嘛。压缩比11现在看很高吗?一个自然吸气家用车把机油看得那么重要,就是在不懂装懂。什么最重要,保真最重要。我别克2.0T发动机吃极护5-30,剪切度2.9的都不烧机油,吃半合成也都没事。。标致自吸你还要求3.5??那个标致1.6T 1.8T发动机的机油剪切度要求。。压缩比。。呵呵。日系压缩比大于11的自然吸气发动机多了去了。吃大黄壳也没事。。还有你一副卖弄的样子,真的讨打。就算有人不懂这些就是智商低?把机油研究那么透彻有什么用。你研究透彻了就应该明白,自然吸气发动机对机...
Motor Oils
The French PSA group issued a set of oil specifications in 2009 in order to exercise greater control over the motor oils used in their vehicles. All specifications are based on ACEA specs but also require further conditions to be met.
PSA B71 2290
Peugeot/Citro?n engine oil specification introduced in 2009. B71 2290 is a low-SAPS oil intended for engines with diesel particulate filters and with Euro 5 emission standards. General specifications are: ACEA C2 or C3 with additional PSA tests.
PSA B71 2294
Peugeot/Citro?n engine oil specification introduced in 2009. Main specification: ACEA A3/B4 with additional PSA tests.
PSA B71 2295
Peugeot/Citro?n engine oil standard for engine before MY 1998. General specification: ACEA A2/B2.
PSA B71 2296
Peugeot/Citro?n engine oil specification introduced in 2009. General specifications: ACEA A3/B4 + additional PSA tests.
PSA B71 2312
Peugeot Citroe?n has developed B71 2312 standard for oils able to endure the most severe thermal constrains along with most modern after treatment systems compatibility. The PSA B71 2312 standard applies to all Peugeot and Citroe?n vehicles equipped with “BlueHDi” Diesel engines fitted with SCR (Selective Catalyst Reduction) allowing NOx (Nitrous oxides) treatment through the use of AdBlue? additive or so-called “diesel exhaust fluid”. The standard also requires improved cold flow properties to reduce hydrodynamic friction of the oil, in order to obtain fuel economy benefits especially when the oil is cold. This extra requirement for cold flow properties allows excellent oil flow at start up, faster oil pressure build up, faster revs raisings and faster operating temperature reach. This type of low viscosity lubricant allows fuel consumption reduction and therefore reduces greenhouse gases (CO2) emissions.
买点卖点 2017/12/04 13:59:39 发表在 主楼
抱歉起了这么一个哗众取宠并且攻击神龙的名字,本人是老款标致508,发动机为EW12A的2.3机头,燃油为92号乙醇汽油,已经连续使用了4锅福斯GT1 5W40机油,最近刚更换第五锅福斯GT1机油,在保养前的近9千公里,我每间隔一段里程都会看一下机油尺,刚做完保养的时候机油离上限差4小格,然后每间隔2000~3000公里消耗一小格,保养之后行驶了7900公里的时候离上限7小格(消耗3小格),不过在行驶了8700公里的时候再看油尺,竟然离上限10小格(消耗6小格),也就是说不到一千公里竟然又消耗了3小格机油,实在搞不明白过了8000公里之后为什么机油消耗会加速,已经排除了发动机有渗漏,并...
北漂憨人 2018/01/31 10:05:39 发表在 99楼
1.不知道你说的“用全合成机油两万公里机油比矿物油五千都好”这句话认真调研没。2.我说的家用小排量自然吸气应该是2.0L上下的。你举例的几个3.0不算家用小排量吧。3.很多全合成机油剪切度都达不到3.5。但是大众原厂首保免费的半合成机油剪切度多少?4.我没给矿物油打广告。全合成自然更好,而且现在国产品牌全合成还有全球购也便宜。但半合成基本满足之前我说的小排量自然吸气家用发动机。而且我2.0T的都吃过几次半合成。5.厂家说明书我不怎么看,就像绝大数车主一样,买了车有几个去翻用车说明的。。我要记得没错,朋友的2.0L世嘉,1.6LC2,机油盖上写的都是5-30的标号。我帮他们买机油,都买的5-30...
