0W-30 (AZO): API SN (Resource Conserving), SM…; ILSAC GF-5, GF-4…; ACEA A5/B5, A1/B1; Chrysler MS-6395; GM dexos1? (supersedes LL-A-025, 6094M and 4718M) Fortified with detergents that exceed dexos1 sulfated ash specifications.
COMPATIBILITY
AMSOIL Signature Series Synthetic Motor Oil is compatible with other conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil’s life expectancy and reduce its performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with AMSOIL synthetic motor oils.
SERVICE LIFE
Normal Service – Up to 25,000 miles, 700 hours of operation or one year, whichever comes first, in personal vehicles not operating under Severe Service.
Severe Service – Up to 15,000 miles, 700 hours of operation or one year, whichever comes first.
Severe Service: Primarily short trips (less than 10 miles [16 km]); turbo/supercharged engines; commercial or fleet vehicles; excessive idling; first-time use of AMSOIL motor oil in a vehicle with more than 100,000 miles; frequent towing, hauling, plowing or driving in dusty conditions.
哦,对了,既然谈到认证,PSA自家对机油的标准且适合涡轮增压车型的Peugeot / Citroen B71-2290不是应该更符合自家的车吗?
http://glonas.by/maslo/Motornoe/dopusk/PSA-B71-2290/
去看看楼主推荐的有几个油是满足该标准的!少在这儿装逼了!
别跟我扯什么ACEA和SAE,那是第三方!
lz推荐的确实不错。我之前也研究了一番机油,国内要找5W-30 A5/B5认证的机油还真不多。
我是6T的车子,最早一批进口发动机的。首保以后换过一次京东自营的银美孚5w-30,因为这是我能找到的为数不多的A5/B5认证的机油了。用下来感觉前期非常顺滑,到了7000公里以后声音有点大。后来保养又换回ineo ecs,到现在又接近7000km,感觉声音没有银美孚大。
lz请问道达尔ineo ecs和银美孚5w-30到底哪个更适合6T?
谢谢
KDS暴鱼 2015-1-30 16:32:16 发表在 17楼
你的质问很可笑也很幼稚
第一,A5/B5的全合成机油,大多数HTHS在2.9-3.5之间,4S给你加的道达尔快驰future 5W30也只有2.9。
第二,选择机油时,各类指标的优先顺序100℃运动粘度150℃ HTHS40℃运动粘度粘度指数≈总碱值倾点。
HTHS考核的是150摄氏度下的油膜强度,但日常驾驶更重要的就是100摄氏度下的粘度。
你天天开车踩到红线吗?
我的508 2.3大多数情况下机油温度就没有超过90摄氏度过,即使是在盛夏39摄氏度的情况下在拥堵的市区反复加速收油减速的恶劣工况下。
新车款没有机油温度表了。但是参考同样使用 EP6 增压发动机的 宝马 和 MINI 的对应车型的情况来看大多数涡轮机在正常工作的情况下,机油温度在100-110...
