hangzhoushu 2016/08/04 15:29:58 发表在 109楼
我看你才是无理取闹加无脑 他说的这些都是需要实践 或者说可以实践的 而他 啥都没有就在那乱讲 混充 知识分子. 有啥意义? 另外- 说实话你真无脑 就这样..
kankan0221 2016/08/03 20:02:53 发表在 98楼
技术贴...我这周末就要去首保了,5个月开了5500公里。基本都在高架上堵车。在机油方面也纠结,也不打算换好再去其他地方重新灌进。所以我到底选择540,还是030?求解答
abc_4295 2016/07/28 11:35:21 发表在 主楼
斗胆写出机油指南,纯粹是为了搏眼球,各位兄弟请见谅。很多兄弟对于机油各种宽泛的概念和众口不一的说法感到疲倦和疑惑,实际上这世间万事万物都有答案,柯南就最喜欢说真相只有一个。这是本人对各种小众机油不感冒的理由:机油这东西在国外就是个低价消耗品,就好像一只牙膏一样,各种超市都随便买。老外花在牙齿上的钱不知道比机油钱高出多少。机油跟白色家电一样,是早就已经完成洗牌的非常成熟的行业,但总是被描述成为充满了机遇和新鲜的事物,好像有许多好的产品默默无闻,等待我们中国老百姓来发掘。机油行业的研发推进靠大量资金、靠OEM和机油厂商共同协作和大投入来完成,如果你是奔驰公司发动机研发中心负责人,你推进发动机制造精...
hangzhoushu 2016/08/01 07:31:46 发表在 79楼
浪费感情 不过是网上找了资料而已 请以亲自实践去证明 否则就不要 自说自话 不然跟键盘车神有啥差别
Rat,
i love the new oil testing specialyl on mobil 1 5w30… the 2 temperatures you tested. I was wondering if you could test the oil at 300 degree as well at least for the the top tier oils… turbo boosting at really high psi, would generate incredible amounts of heat…. so it would be of interest to alot of turbo users which oil actually protects them best…
Your new oil testing now explains why some turbo experience thrush bearing damage on mobil 1 5w30 during high boost applications… were temps in the turbo are at higher then normal operating temp, thus lowered oil film stregth.
keep up the great work!
dez
Hi again Dez. Previously I have tested some oils at 275*F and at 325*F. What I found with those tests was that their wear protection capability had basically leveled off by 275*F, and then stayed essentially the same at 325*F. Based on that, you can look at the values for those oils that were just recently tested at 275*F, to see what you would also expect to see at 300*F. And for any future high temp testing, I can test them directly at 300*F.
For Turbo guys looking for a 5W30 oil that still performs well at elevated temperatures. They could consider:
5W30 Quaker State Ultimate Durability, API SN, GM dexos 1 approved, synthetic (gold bottle)
and
5W30 Pennzoil “Ultra” Platinum, Pure Plus Technology, made from pure natural gas, API SN, GM dexos 1 approved (dark gray bottle with a blue vertical stripe on the label)
Both of those oils performed very well at 275*F, with only very small drops from their 230*F values.
Take care,
540 RAT
这是作者给涡轮增压引擎推荐的两只最耐高温的机油,适用于任何内燃机最严苛的工况,在一个绝对高的温度之下抗磨性能相对110℃暖机油衰减最小。远超Mobil 0w40。别说汽油机,游艇都用。
再次证明了粘度不决定抗磨保护能力的观点。
我在正文分享了《TECH FACTS, NOT MYTHS》的股沟翻译版和英文原版,有兴趣可以深入研究,原文里作者给出了足够多的证据和测试数据。
zhaodaye21 2016/07/30 13:53:05 发表在 30楼
我都是用的免费机油,八九千公里才换,对发动机损伤大吗
