一些路人的建议:
The dealer told me to drive with more "enthusiasm" my judders have gone away. Strange advice yes but it seems to work.
If you can drive in Sport mode once a week the car will thank you for it usually.
The DSG's biggest enemy in my view is unpredictable stop/start driving, where you're following someone slowly and don't know when they're going to stop or keep on rolling. Clutch just doesn't know what to do and it makes for a bad ride whereas in a manual you'd probably just keep the clutch in a lot of the time and roll.
I will admit these days I put the car in neutral as the car draws to a near stop. Just on the thought that the plates may be at friction point and needlessly causing premature wear
I'm appalled at VWA's attitude to this horrendous situation, they are clearly shirking their responsibilities.
I can't believe there isn't a massive consumer backlash to these dsg issues in Australia, I heard in China VW were forced to extend the warranty to 10 years. If I don't get an appropriate response from VWA to my issue, I'll definitely be taking it further.
vw8797 2013-3-4 08:37:47 发表在 140楼
纯属凭想象。手动挡停车不减空挡将离合踏到底是半联动?DSG变速箱停车他怎么不分离呢?控制程序实现合或离是比实现半联动要简单很多,他怎么就是半联动呢?频繁换档任何变速器都磨损。其实DSG根本问题是7速干式离合器,设计初衷是积极换挡、提高换挡舒适性,可能是控制程序与实际驾驶状况不理想,造成散热不好,离合器片材质问题达不到设计要求,6速DSG根本没问题。
咨询国外专家给的答复:
Fair chance it is just the clutch adaptations getting out of whack.
Drive it in manual mode for a bit. Especially in the regime where you reckon the clutch take up is getting rough. From what I can gather from your description, this is from 2nd to 3rd. So the K2 clutch disengaging and the K1 taking up. If there was a genuine clutch problem, logic suggests you would expect to see it as all the odd gears engaged, whereas you are only reporting it from 2nd to 3rd. So quite possibly the current adaptations for the gear engage points and clutch positions during this change are out of whack. If it was my car I would just reset the clutch adaptations to back to basic settings with my VCDS. then let it adapt formXSS scratch again. But as you don't have VCDS, drive it around in manual mode a for a while. Especially through the gear change you reckon is dodgy. See if it improves as the adaptations change. Good chance they will.
BTW the 2nd to 3rd change is the first point at which the K1 clutch fully engages. In a normal leisurely start off, the K1 clutch actually slips all the way to 2nd gear. So this is why you wont be seeing it when you first move.
My dealer recommended I pull off from stops or slow corners more aggressively in D....it actually works so far. Most of my judder experiences have been when driving like a granny coming out of slow uphill corners. Just putting this out there for feedback.
37G7 DOES NOTHING REGARDING THE DRIVABILITY OF THE VEHICLE
What it does is it updates the software that controlls the mechatronic unit of the DSG because a certain part number of the mechatronics unit was built and coded incorrectly which meant that the control valves did not fully seat when inoperative. This would lead to premature failure of the mechatronics unit and require replacement. This becomes an issue when the vehicle is left idle and not operating for an extended period of time, i.e. sitting on a boat for 6+ weeks while making the journey to Australia from Bremerhaven.
If you are still having shuddering issues, it is more likely a faulty mechatronics unit causing the clutches to slip more than they should. They can test the function of the mechatronics valves using the VAS system, you can also do it yourself if you have VCDS but you will not know what the required specifications are for the valve operations.....
红灯60秒内用AUTOHOLD,超过60秒直接P档,我觉得DSG最好不要频繁使用N档
乙宸Bingo 2013-3-6 22:45:20 发表在 157楼
什么叫凭空想象?我有2年手动挡汽车的行驶经验,我什么时候提到 离合【全踩完】是半离合?你在搞笑吧?
首先我普及下尝试:手动挡,离合大概踩下去1/3—1/2是半离合,具体踩多少因车而异。
其次,DSG停车是否半离合,完全可以自己体会,我为什么说DSG挂“D”挡是半离合,具体表现有以下两点:
1、看瞬时油耗。“D”挡停车状态下的瞬时油耗和“D”挡怠速行驶一致,而停车状态下换“N”挡,瞬时油耗有所降低;
2、身体感受。“D”挡停车状态下,仔细体会,会有轻微抖动,而“N”挡状态下,没有抖动。“D”挡会有轻微抖动,跟手动挡半离合停车状态情况相似。
所以,从油耗和身体感受这两方面判断,DSG“D”挡停车状态下,有极...
tym3228 2013-2-14 12:59:36 发表在 主楼
DSG变速箱等红灯一定放空挡,新技术一样需要正确操作的。
DSG双离合器车主使用不当难辞其咎 。
言归正传,开过手动挡车的车主都清楚:在离合器半联动的状态下,猛地踩下油门加速,就会有一股烧糊的味道传入车中
。这就是离合器片由于突然施加过重动力快速升温、严重磨损的表现。长期如此操作,轻则影响变速器寿命,重则造成离合器打滑,致使汽车失速,严重危害交通安全。
在混乱的拥堵路段,一些大马力德国车抢行猛拐,加塞,急加速等现象
,大家早已司空见惯,其中不乏一些装备了DSG变速箱的大众汽车。由于DSG结构类似手动变速箱,以及它工作原理的特点,在拥堵路段,DSG变速箱的离合器经常处于半联动状态
。突然施加...
